Premix Mode operation on exhaust temperature control occurs after approximately 70% load. By lowering the allowable minimum IGV angle, exhaust temperature control operation and Premix Mode can be extended to lower loads down to approximately 40-50% load.
At our site during load reducing it has been multitimes observed that GT did change mode to Extended Lean Lean IBH did not open. Very few times IBH opened and Premix mode remained intact approximately 50% load.
Can any one tell me what are conditions for IBH Operation? What is impact of system frequency on its operation, did low frequency limit/restrict the IBH to remain close? and what is the impact of climate/atmospheric temperature with IBH?
Because IBH is like mystery for me. Totally dependent on IBH while load shedding. and most of the times reduce load to remain in Lean lean mode to avoid extended lean lean, can not fulfill the demand of load center because IBH do not open while reducing load.
What are exactly conditions for IBH opening to support the premix mode on lower load operation?
