In order to simulate the project which i am working on now, I need to connect both PLC program software (Concept2.6) and XBT-L1000 v4.5 (HMI software) to a real PLC with CPU 113 03. The reason I am doing this is because I do not have a Magelis touch screen.
After making the connection is solid, by changing the status of the program at the Concept2.6 end, the XBT-L1000 simulation window should react relatively to the change.
So far, I did connect the Concept2.6 to the real PLC, and now I am having a problem of communicating between XBT-10004.6 to the real PLC.
