Hello
I am currently specifying instrumentation powered electrically to achieve the following:
On the occurrence of a low pressure downstream of a PCV, a low pressure switch/transmitter will de-energize two upstream pumps via their individual on-off hand station.
From this same low pressure signal source we require the actuation of a shut-down valve to its Fail Close state.
The power supply will be sourced from nearby MCC and there is no instrument air on site.
To date I am looking at the PressureGuard self-contained hydraulic emergency shutdown system from Emerson, but this device will only bring forth the closure of th SDV. however I still need to de-energize the two high pressure pumps upstream.
Any recommendations would be appreciated.
