K
I have a drive IQ2000 Electro Craft Model PDM-20, series H002067, the output voltage is 230VAC 3ph, output current 10Amp, peak current of 20 amps. the drive is coupled to a servo motor Reliance Electric Model H-4020-P-H00AA, which has an MPA. RMS CONST. 5.7A, AMP. 16A PEAK RMS.
Both control an auger filler of about 300mm long and 29mm diameter and 358gr.
The servo drive gave Iaverag fault. we have to change a current transducer LEM model HNC-100P-2 bad, but do not have the electronic circuit diagrams or documentation with these driver settings.
I appreciate any help you can give me
