L
I have a old Mark V which has UV-Tube flame detectors powered by 335VDC from the PTBA term. board in the Mark V. I need to remove the existing 335VDC to the PTBA terminal and replace with existing 24vdc power from the Mark V (was told that the exiting unit has a 24vdc with 1 amp output). New flame detectors require 24vdc. Did not want to install an additional transformer in the cabinet.
This is the first Mark V that I have worked with and sure could use some help.
Cordially,
Larry
Cordially,
Larry
