L
Background:
I have a client with an existing Desktop computer running Windows 2000 NT with WW InTouch 7.1.6. The PC has a PKTX card that communicates with a SLC-504 (Master PLC) using DH+ via wwRSLinx as a DDE Server through RSLinx Classic OEM. The Master PLC controls and monitors four (4) other PLCs on the DH+ network.
We have recently upgraded to a new Desktop running Windows 7 and thus upgraded to WW Archestra 2012 R2 (10.6). The old program was migrated and communications have been configured within InTouch/WindowMaker, since wwRSLinx is no longer an option. All settings in RSLinx are identical to the old PC.
The problem:
Communications are extremely slow and have a tendency to freeze completely. This communications failure (freezing) seems to happen at random times. Most recently it was running correctly for about a week, then the operator changed a setpoint and communications froze again. A full day later, still nothing had updated, including trends.
I have tried various tweaks to the communications settings in both InTouch and RSLinx hoping to find something that may have been overlooked, with no luck. The most recent modifications included changing (WonderWare) "only update active tags" to "update all tags". It runs better updating all tags, but still lags.
Outgoing commands on the old PC would send instantly, but have a significant delay on the new PC. When changing windows, Incoming information would update on the screen within seconds, but now takes at least 2 full minutes if it shows at all.
Needless to say, the old PC has been put back into service while we try to figure out the issue.
I'm considering trying to run the old 7.1.6 software (with wwRSLinx) in Virtual XP Mode. This would then require the PC to be setup to automatically boot up into XP Mode.
Has anyone done this before?
If so, could anyone walk me through this procedure?
Any help offered is greatly appreciated.
The problem:
