H
We are facing a problem while communicating with Motrola Moscad RTU CPU 300. It has modbus protocol and we are able to bring around 300 modbus registers using kepware opc server but there are some addresses like 8XXXXX which does not look to be standard modbus addresses. And also we are not able to get these registers values using modbus protocol. These are around 50 registers.
These registers are getting the data from Omni Flow computer but as these are defined in Moscad RTU so ideally these registers should be available on modbus protocol as well. But Unfortunately we are not able access the values of these tags through modbus.
if anyone knows how to bring these registers values into an opc server or other application/driver then please do let me know.
Any help in this regard will be really appreciated.
Hassan Tariq
Hassan Tariq
