When var (reactive power) is drawn by the synchronous generator (or Alternator) from the grid, the amount is limited by capability curve, which is a characteristics of the particular generator. But if excess var is drawn what will be the problem???
Secondly if the excitation breaker trips, and the generator connected with the grid didn't trips, what will happen? Will it still continue with the same speed of rotation (rpm ,3000 in 50 hz system), taking all var from grid system???
please Sir give me explanation
