SEPAM series 40 Measurements & Diagnosis format
Abdel-Qader
The SEPAM "protection relay" 40 series has some of the measurements with 16bit (WORD) format and some of them in addition to the diagnosis are 32bit format (DWORD). My question, can i configure all the MB_MASTER blocks DATA_PTR with 32bit format arrays?
in other words, for example, if a voltage for the three phases is 16 Bits format and the DATA_PTR is array with DWORD (REAL) is it OK?
The second question is related to the SEPAM faults (Earth fault, Overcurrent, Under voltage, Short circuit, Unbalance), how can we get their status i think each fault has a BOOL format (0,1), but i read the sepam 40 manual and i didn't find their addresses?
