R
It is observed that in stand by gas turbine (Frame 5) ratchet jaw clutch is getting disengaged automatically after 25-30 minutes of stoppage of scheduled ratcheting. NRV checked for passing and no passing observed. both the hydraulic cylinders replaced checked and found no passing. earlier one installed cylinder found passing. oil supply line filter replaced. 33 HR limit switch adjusted. problem is still persisting. Kindly advise.
