H
there can even be a technical mistake in the question please do correct it as i'm a trainee.
the gateway-x is the master which controls 25 anybus (the slaves) with two port. one end of the gateway-x is given to the plc and the other end is given to the anybus. the anybus are interconnected in ring topology. The second port of the 25th slave will be left floating which is supposed to be connected to the master to support DLR (device level ring) so that in case of any problem in slave connection the DLR must do a rerouting. please do help me with a device with allows DLR, connects the slaves in RTU and also connects the port 2 of 25th slave with the master for the operation of DLR.
