We have frame5 gas turbine machine with mark 5 control system. We are using windowsNT for HMI. now machine is at shutdown condition for combustion chamber inspection so that we removed both the spark plugs. now the question is we want to check both the spark plugs operation. for that what are the signals i have to force?
i checked in the rung display it is showing L2TVX- (ignition permissive) as Input and L2TVX1- (ignition transformer), L2TVX1A- (ignition transformer Aux relay K1), & L2TVX1A_REF (description not mentioned) are Output, ie, 3 outputs. Can anybody explain about this rung? Description? Outputs? and Logic signals required to force, to test the spark plug externally in a safe manner?
