I
We are on the startup of GE gas turbine. The startup failed in “fail to fire alarm L30D13”. We noticed that the compressor discharge pressure (96CD) is not increasing along with the HP shaft speed. We use steam turbine for startup.
Someone can please advise my understanding is correct. If it is what could be the reason for the compressor discharge pressure not to increase along with the HP shaft speed.
