PSV Masoneilan 21700 LO DB (I/P 3 - 15 psi)
The valve when isolated work well. but after open, the upstream valve it can't close to 0%. we can see the plug stem lift up even with the valve in manual and command it's 0% (passing more than 10% for DCS command ="0 %") and DCS operators experienced troubles in controlling the pressure.
We check the loop and all it's ok.
Can be because there is a reduction pipe size from 4" (pipe) to 1" (body valve)?
Thank you for any help!
