T
Greetings
I used Siemens PLC with CP343-1 (IP 192.168.0.1)
And also Telemecanique PLC(Premium) With ETY110ws (IP 192.168.0.2)
I used the function FB108 (Modbuscp) in Siemens PLC
And also the setting for the Netpro In siemens plc has been done. Telemecanique PLC (premium) on-line mode is identifiable by Siemens.
For reading and writing data in Telemecanique plc how to act?
Siemens has also been used in Telemecanique plc (Premium) IP address
My problem is Telemecanique.
if I used DB11 in Siemens PLC with Start_DB:1 and End_DB:100 For Send to Telemecanique (Holding Register) (Settings in the FB108 in siemens are correct).
How will the data be received in Telemecanique plc (Premium)?
Do you have a specific Function (ADR) be used?
I used PL7 V4.4 and I cannot use ADDM Function.
