I would to make a backup of the project which is running on the QuickPanel View IC754VSB06MTD-LH and I could not upload the project. the device has DB25 port which is using to communicate with the PLC AB Micrologix, and it has an Ethernet port. I have used an Ethernet crossover cable but without success. and when I create a new project and I select the right quick panel view, I could not see the Ethernet in Com port in the target properties.
please help.
please help.
