R
When performing an online waterwash, our 6B changed from Premix Steady State to Lean-lean negative. We backed the generator down to lean-lean positive and started loading the turbine. It changed back to Premix and then we base-loaded it. We run in baseload all the time. This is the second time this has happened. Both times were when we were waterwashing.
