we have a reliance motor 450 HP, 380V, 60 HZ, 602Amp, so it is run a horizontal pump to inject a water in oil wells.
So we used an VSD (518 KVA) to run this motor through 400 V, 50 HZ gen. set and after a few sec from start the VSD recorded 900 AMP and Shutdown with over load trip signal. we disconnected the coupling and try to run the motor at no-load with the same result.
So if any one help in this issue why the large current driven? and take into mind the shaft run smooth and have no sound.
