Dear all,
We have a small in house CPP consisting of two gas turbines of Hitachi make, Mark V equivalent machines, with 22MW capacity each and a steam turbine. We have commissioned two gas turbines successfully, but recently we encountered a problem with one of the gas turbine, which tripped due to contamination of lube oil with fuel oil, which is a different issue.
I have one gas turbine running with the in house load of 8MVA present on the generator. The 22MW gas turbine is rated 27.5 MVA with 22MW generation at 11kV, 0.8pf lagging. I need to start one Induction motor of 7.6MW in decoupled condition and I have a soft started to start it. But, as per the vendor's data, the initial MVA requirement by the motor shall be 20.12 MVA on 6.6kV level with 0.1pf lagging for 10~20 seconds even with the soft starter in decoupled condition. During design stage it was considered that coupled condition of motor shall be started with any two generators running in synchronism. Since, I need to take a no load trial of the motor before coupling it, I need to start the motor on my gas turbine generator.
My machine is running with HSD currently. I am running my machine presently on Isochronous mode. My questions are:
1. Is it possible to start the motor on my GT without tripping of my complex? My U/V settings in the downstream are set at 80% for 1 seconds.
2. If at all if it is possible, what are the changes in the running parameters I should change.
3. I have a grid power also, from which I can extract upto 7MVA (above that my upstream supplier substation trips at overcurrent). So, is it possible to start my motor with grid synced with GT?
Please help me in this regard. Thanks in advance.
P.S.: My concerns are towards the response time of AVR, Voltage drop of the generator and the MVAr capability of my alternator.
