I'm currently doing a project on PID controller using 8051.
Here i'm using a pressure process station. I have a pressure sensor (piezo resistive) and a i/p converter both uses a 4 -20 ma current loop. This Pressure will control a globe pneumatic valve to the Pressure tank.
My questions are,
1) How to read the signal from the transmitter?
So far i've searched internet and found that a 24VDC is supplied to the transmitter and it is read as voltage through a 250 ohm resistor. Hope this will work fine.
2) How to give output to the i/p converter?
I've no idea on how to make this 4 - 20 ma output current loop? The i/p converter I've is loop powered.
Please help me.
My questions are,
Please help me.
