We have a review for an upcoming exam, and in my studies I can't seem to come to a conclusion of the answer. The question asks,
"For a wet leg pressure level measurement system, if the wet leg seal fluid starts to evaporate, will the level signal change? If yes, will it increase or decrease? Briefly explain."
As the seal fluid should have a greater S.G than the process fluid, in this case upon the evaporation of the seal fluid, the process fluid will cause in an increase in the level transmitter reading?
Any help would be greatly appreciated,
Thank you!
Thank you!
