P
I have a project where I have a panel that is currently installed in a non hazardous area but that needs to be pressurized.
I need to measure the internal pressure of the panel to ensure that it does not exceed 2.5 kPa.
The transmitter will be installed in a panel that does not have any access to the outside so a DP transmitter is not an option. The panel needs to be kept above 50 Pa.
Are there any suggested brands or any other way that I can get the ranges and resolution I need.
All help appreciated.
Thank you.
Thank you.
