HI,
I WORK JUST IN NATURAL GAS AND CHECK THE MINIMUM TEMPERATURE OF NATURAL GAS INLET IS AROUND 23 DEG-C, AND THE DEW POINT OF HYDROCARBON IS -35 DEG-C, AND THE WATER CONTENT IN NATURAL GAS IS 8 MG/SM3, AND THE PRESSURE AFTER SRV VALVE IS 22.5 BAR.
THE TEMPERATURE NATURAL GAS INLET IS suitable.
I work just with natural gas and primary mode.
WHY WE see a lot of coke around the atomizing nozzle?
At any start the unit the pressure of atomizing is low alarm. after the increasing the load the pressure of atomizing air go higher than low alarm.
thanks a lot for reply
