how to detect over pressure
T
tapas
I am building a system where I require to detect if the pressure inside pneumatic pipe has gone below 4 bar or above 6 bar pressure. If the pressure goes out of this limit I should be able to cut off the instruments from this pneumatic line automatically. As I am new to this, please suggest me which kind of sensors should i use for this kind of application.
Thanks In Advance.
Google "industrial pressure switch".
You'll need a switch assembly (sensor and switches) with two independent switches, each with its own setpoint adjustment.
One switch is set to trip 'low/falling' at 4 bar, the other to trip high/rising' at 6 bar.
