Don't know exactly what I'm doing.
Following directions on one unit, don't have directions on another. Need to learn, Can't find data on web. Looked for days.
Advice, info, and opinion welcome.
I'm trying to set up (calibrate) a rotary LVDT.
We run the signal through a controller like MOOG or an A-308 signal conditioner. We are trying to get a linear output from 0 to 6 volts. Everything I find on the web gives the transformer theory, great but I understand that.
What we are trying to follow is a chart that shows 80 degrees Voltage A-B .0234 milvolts, 60 degrees voltage a-b = .0344 millvolts etc. Is this enough information? We measure A-b our values are a-lot different. And this is before the signal conditioner. Is there some standard we should be following? What are we doing wrong? I there something I need to read. Just anything to help get me going in the right direction..
Much Thanks,
David
Much Thanks,
David
