Hope somebody is kind enough to assist:
Upgrading a 45+ year old system, I have the original <b>Woodward EGB</b> governor linked to a new <b>Woodward 723PLUS</b> (p/n 8280-412 Rev. H). This is for power generation on an oil rig.
The persistent problem is as follows:
System set to "idle". The engine will come up to the required 450rpm after start-up. Once the required water temperature has been achieved, switch to "run" mode (900rpm). The engine will momentarily spin up to 525rpm for 1 or 2 seconds and then drop the revolutions right down to cut out.
For the past two days I have been going through the maze of configurable options. Trying all kinds of combinations in fuel supply, droop, etc. To no avail. I am at my wits end.
The Woodward EGB governor uses 20-160 mA for the actuator control done by the 723PLUS (0-200).
If somebody knows how to apply the correct settings or possibly has a config file, I would greatly appreciate the help.
