Is a Ge Mk6 Speedtronic capable of dividing two numbers both with values between 0 and 1 to three decimal places and produce an accurate reliable result? I know trying to do this with a Mk5 would not yeild good results but am not sure about the capability of the Mk6.
If this was not programmable by the user could it be programmed into the eeproms by Ge?
Also can the Mk6 deal with a square root calculation and negative values?
Any opinion would be greatly appreciated especially from CSA.
Thanks in advance.
Thanks in advance.
