Dear All,
I am doing a small project with Schneider PLC. The below are the details.
Master PLC: CPU 67620
Slave PLC: M340
Radio: GE SD04
Communication Mode: RS 232
Master PLC Node: MOdbus Plus
I am adding to the existing network, where in there are similar RTU are added. I am using MBP_MSTR block for communication.
But when i try to run the block it is giving the error. The error code is as below:
Error- 6206
(Non Existent Slave device register requested and Slave device is down)
But in my slave device i can see the counter for TX/RX are increasing whenever it is polling.
Does any one face similar kind of problem.
Your suggestions are welcome.
Thanks...
Slave PLC: M340
Radio: GE SD04
Error- 6206
Thanks...
