GE Sprits skid Coax solenoid valves cause major water hammer from boiler feed to fog nozzles. Wet compression on 7FA.
Trying to find a retrofit solution to replace the coax solenoid to slow the actuation to reduce water hammer. 265F water from boiler feed max flow rate 40 gpm 2550 delta P.
