N
CSA
in frame 5 GTG there is ratchet system not exist hydraulic pump HQ.
so can you help me or give me the correct procedure to make calibration SRV with HR pump because the HR pump is CC normally they work max 15 min? exact?
and for HR work at 33 barG normal condition
and some one tell me you go at crank mode to make calibration with mechanical pump not use HR pump
can you help me
can you help me
