Hello all,
I would like to get your views on measuring the lube oil level for monitoring purpose.
Irrespective of the type of oil in question, i.e. synthetic or mineral lube oil, which rate is suitable to measure the lube oil tank? the absolute level from tank top to tank bottom, or the working level (with minimum and maximum indicated) as dictated by the P&ID of the system's drawing.
By using the absolute dimension and total volume for the tank, it is almost double in litre per height of oil if i compare it with relative measurement which takes into consideration of the working height and oil volume.
your experiences and discussion are appreciated.
