Our site experiences fuel gas supply pressure fluctuations ranging from 15 bar to 21bar. The low gas pressure alarm setting is 17 bar. during low gas pressure <17 bar it is not possible to operate all the 5 nos frame6 DLN1 units at base load (premix mode) due to rapid pressure drop to <14 bar. To avoid shutting down the turbine we chose to operate 2 turbine on part load (lean lean mode) for 10 to 12 hours a day while the other 3 turbines are at base load (premix mode). once the gas pressure increases in the night the 2 units are back to base load (premix mode).
what are the consequences of operating the DLN1 unit of lean lean mode for such a long period? in this mode the diffusion flame is present in both primary & secondary zone. we had notices damages to venturi areas of the liner. please specify what is the maintenance factor for Lean lean mode of operation? GE specifies MF=10 for extended lean lean mode of operation but does not specify for lean lean mode. feed back will be of great help.
