Earthing a Collocated Shelter That Feeds Separate Generators
banny
we have two collocated shelter that feed from one generator and spaced from each other about 200 meter. all equipment are sensitive and need to be earthed so i have to ground both side. but its not practical bonding them together so that have an earth ground system. i want to use one Y/Y transformer to break the path of ground loop. should one side of the transformer earthed or both sides? is any body have common on that?
