Sliding Mode Control
Andrew
Hey all,
I'm an Electrical Engineering student undertaking an Advanced Control subject. I need to design a sliding mode controller for a gantry crane that limits the swing angle to say, less than 15 degrees while the suspended load is moved across the gantry beam. I was wondering if anyone could give me a few pointers. I have already successfully designed and implemented a pole placement controller but I am having a lot of trouble getting my head around practically designing a sliding mode controller.
The crane is a single input two output system, the dynamics equations are,
x(s) = 5.8/(s(s+2.4)
Theta(s) = -5/((s+2.4)(s^2 +7.8))
If anyone is willing to help and need more info my email is [email protected].
Thanks in advance.
Andrew
P
Peter Nachtwey
Limiting the sway is going to be a function of limiting the acceleration of the motor system x(s). That limit can be determined if you look at the equation for a swinging pendulum.. Usually people are more interesting in reaching the final position without the load swinging at all. There are algorithms for this but they require a long convolution filter with the period of the swinging.
Sliding mode controllers are easy. If it looks difficult you are doing something wrong. Optimizing the performance may take some effort.
Do you use something like Mathcad, Matlab, Scilab etc?
These pdf files may help for starters
http://deltamotion.com/peter/Mathcad/SMC/
