V
Hello!
I have a problem with Telemecanique TSX Premium PLC. It is only one rack assembly, with some extension modules like CANopem, 2x AS-i, 1x analog input, 2x digital I/O, Counter and few Ethernet modules. Just to make it clear: i haven't modified anything in the system in the last year.
The problem is that it at some random moment one part of the production line just stops. The only trace that I found is a fault in the Diagnostic viewer of Unity Pro software. I also know that all the nodes on one AS-i bus show error for about a second. That is probably the cause of the line part stopping. The other AS-i bus seems to work fine, but haven't confirmed that yet.
The fault message from Diagnostic viewer is %S119 Local I/O fault Area: 0. What exactly is the fault about. Is it the PLC or some other module in the rack? I'd be very grateful, if someone could give me a hint about what to do or what to check next.
Best regards
Rait
Best regards
Rait
