I have previously wrote a programme for an automated machine I have built using a Zelio logic relay.
It’s a simple timed sequence using cycle timers. When the door is shut and start button is pressed the 5 timers start there off/on delays.
I now want to switch to twido PLC to better communicate with our HMI and to be able to alter timer presets.
I have used a series of TON + TOFF timers to get the same off and on delays which seems to work.
But if I put a (E-Stop) or (reset) switch in. I’m unable to cancel the timed sequence I need some way to be able to stop all TON+TOFF timers
I noticed the TMi.V is read only.
Is there any way to stop+reset timers to 0
I’m sorry if this is not enough information please let me know and I can maybe take screenshot of program to better explain.
