Preferred would be at stand still. However the units I worked, the turning gear was ~3 rpms. When purging on TG, the expected volume to purge should be doubled.
I would not know the recommendations for units with faster TG, I would expect the recommendation would be do not attempt on gear
EXTREME CAUTION should be used during purging as a fatal incident is possible.
