Here the scenario;
We have 4 engines on line on our main switchboard. The switchboard is split by a bus-tie, so 2 engines are supplying Bus A and 2 engines are supplying Bus B.
In order to stop 1 engine we have to close the bus-tie and make the board common. We do this by syncing the 2 boards together through our Power Management System (PMS). The PMS then either raises or lowers the speed of engine 1 and 2 together to match that of engine 3 and 4 so the bus tie can be closed.
Then this happens; Engine 2 seems to take all of the load and engine 1 goes into reverse power. Its almost as if engine 2 responds quicker than engine 1, or engine 1 is responding a lot slower.
We are unsure why this is happening; it runs fine on its own and when paralleled in with any of the other engines. It only happens then syncing in the bus tie between the 2 switchboards.
Could this be a lack of excitation on the alternator of engine 1 or the AVR on engine 1 responding to slowly?
Any ideas guys?
Cheers
Martin
Any ideas guys?
Cheers
Martin
