The steam turbine lube oil system I refer has a LP discharge from MOP (around 3bar), then there is a lube oil cooler with 30 degC set during the first period of the speed up (high viscosity) and then the set changes to 40 degC around 1400 rpm (low viscosity).
After the cooler there is a relief valve with set pressure of around 1.5 bar, later there is a filter, accumulators and finally the bearings. The lube oil pressure indicator is between the accumulators and the bearings.
There is a important lube oil pressure fall while speeding up from 1900 rpm (heat soak ) to 3000 rpm. My first question is anyone know why?
I was wondering about a change of the MOP point of operation due to change in the oil film on the bearing while speeding up. This would mean the pump is working in a point with more less pressure head and more flow, pressure at the relief valve is the same (1.5 bar) but because of the higher flow, there is higher pressure drop trough the filter up to the pressure indicator.
But this theory vanishes when sometimes because of the lube oil pressure reduction, the AOP starts up and pressure in the pressure indicator rise to 2.5 bar.
How can it reach 2.5 bar if the relief valve was adjusted to 1.5 bar???
Does anyone have an idea about this?
