Loss of Communication Between HMI and MARK V
H
hanio3001
Hi sir:
suddenly we loss all the values and communication between Mark V & HMI.
- i check the cable is okay
- i check the communication resistor is okay
Andrew Turner
At the HMI you need to bring up the DOS prompt panel.
There you need to change directory to F:\Unit1
Now type in command Arcwho.
This process should give you the nodes that are present on the Arcnet system.
