Frame 5 Crank Starting Issue
Stan
Frame 5 Combustion Turbine Diesel Starting Engine Starts going to 16 rpm then Normal Starting Failure with Turbine Indication Mark 5 after 3 minutes into start up. Ratchet system is ratcheting any ideas what might be the problem?
Stan Wilhelm
Roquette
[email protected]
Looks like a problem with Diesel Engine Lube Oil Pressure, probable tag is L63QD(N). This will stop engine accelerating with 20DA. Cannot remember the setting but > 9 psi sticks in my mind.
