Frame: 6B GT
Was running for long without shutdown and tripped due to GCB issue. Several restart attempted but tripped on fail to ignite.
Fuel check valve ok & check valve operated between 5-7 KG/CM2 and are OK.
Flame detectors cleaned and ok.
Purged the fuel line from the divider to the nozzles.
Spark plugs were tested ok.
Liquid fuel stop valve (20Fl-1) & Liquid fuel Control valve ok.
Checked the spark plug and ok. Fuel strainer & Filter clean.
