There are two basic types of drops that can be added to a system: workstation and controllers.
To Insert a DROP:
1. Launch the Ovation Developer Studio
2. Use the system tree (in the hardware view bar) to navigate to the drops folder:
System
Network
Units
Drops
3. Right click on the drop folder.
4. Select Insert New. The Insert New Wizard appears.
5. Type the drop id value field(1-254).
6. If a partner drop is to be used, type the partner id value field (1-254)
7. Select the desired drop type from the drop-type pull-down menu. then, to finish inserting a drop for:
The controller sim, controller advanced controller or advanced sim controller.
or The operator station, sim operator station or base station.
or The virtual controller host....
