Hi.
I have few questions about how gas turbine works at part load when DLN I combustion system is employed. This is Frame 9 gas turbine - PG 9171E
Last week a had an appointment with peoples who work in gas turbine combined cycle power plant. They use Pre-select load control while operating at part load on Droop Speed Control. The position of inlet guide vanes is automatically modulated to control fuel/air ratio in combustor.
As I said in my latest post I am trying to develop a mathematical model of this gas turbine. Now I am thinking how to simulate a behavior of unit at part load when IGV are modulated to control combustion process (amount of air supplied to DLN I to avoid flame instability) and Pre-select load control is enabled and active (not IGV temperature control). I found here:
http://www.control.com/thread/1403944262
a following sentence (second post):
Two last things. First, if the turbine you are working on has DLN (Dry Low NOx) combustors, IGV exhaust temperature control is not operator-selectable; it's always on.
Questions are:
1.How gas turbine operates at part load (with DLN combustor)? IGV are modulated to control fuel/air ratio in DLN I or to maximize gas exhaust temperature? I am really confused about it. What happens with speed control?
2.If at part load amount of fuel is controlled by speed control (in this case Pre-select load control) how a position of IGV and exhaust temperature are changing while load is changing?
3.Can I assume that at part load unit operates using IGV exhaust temperature control? If this is true, actual exhaust gas temperature TTXM equals TTRX (for particular CPD)?
Best regards
Marcin
Questions are:
Best regards
Marcin
