V
Frame v mark vie control system having input supply 125 vdc through battery charger and DACA. EOP was started from MarkVIe and stopped the same. During EOp stop command given, after 200 mili second interval of off command Control supply 125vdc dropped up to 105 vdc. P125vdc is reaching 40 vdc and N125vdc is -63 vdc. G125vdco is reaching up to -20.
We have checked EOP on only DACA. 125vdc isolated from charger and 125vdc input MCB put off from mark vie. No voltage dip was observed on DACA. Only dip observed on 125vdc direct supply system.
One more activities done, EOP checked on only battery and dip observed up 90vdc.
Kindly give the idea to resolve the problem.
