R
Greetings,
I seem to missing something here. It is likely a fundamentals issue and I am not recalling something.
If I put a gP transmitter on the bottom of a tank filled 90% full of mineral oil will I be able to measure the weight of the oil over a range of temperatures? Assume the tank is vented to atmosphere.
The argument is that as the temperature goes up the volume goes up However, the density goes down so the pressure on the transmitter should remain the same since the mass of the oil is rho * V the mass should remain constant. Yes the volume increases so the level does increase but the density goes down so the mass remains constant.
Regardless of the temperature, volume, and density changes the mass must be staying the same.
Questions; How would I detect a leak if the level (volume) is constantly changing? Is the pressure measured by the gP transmitter going to be affected by the density of the oil (I say yes)? If so why does a temperature induced change in volume/density cause the pressure on the transmitter to change?
Thanks,
Ron
Thanks,
Ron
