E
Where the signal L4ex_strt_ss is produce In a Mark-v in a gas Turbine.
The signal is in the IO.ASG as EK2K do01 (l4ex_strt_ss) start request for ex-2000. It is an output from the mark-v to the ex-2000. In the dynamic rung display appear as a normally closed contact only. I can't find the genesis of the signal. Where and how it is produce? I have steam turbine mark-v control and in the dynamic rung display appears as a coil with his logic.
Elvin
Elvin
