Hii List,
I have an assignment for controlling ph level in an acid scrubber.
The system work as follows:
Acid vapors are coming from an industrial acid cleaning system to the scrubber
a caustic pump is pumping caustic to the scrubber to neutralize the acid. Right now the pH sensor is in the bottom of the scrubber.I would like to move the pH sensor to the stack in order to control the outgoing gazes to the atmosphere.I have been told that the pH sensor will not work in the stack. Can any body help to solve this
problem.
Albert Avidor
problem.
Albert Avidor
