compile cvs tree
Mario J. R. de Sousa
Arne wrote: > I tried to compile the cvs but get a lot of errors? > > ie. compile logic/iec/iec.y gives some errors. > Do you get any errors besides this directory? This directory contains a IEC language compiler that is not yet complete. You might want to try out an alternative but much simpler compiler in logic/il. > I just want to play a litte with the demos and get try to understand the > structure of the softplc. -- ther isn't any documentation abou this ?? > Sorry. At the moment the only documentation is under the /doc directory. Cheers, Mario. ---------------------------------------------------------------------------- Mario J. R. de Sousa [email protected] ---------------------------------------------------------------------------- The box said it requires Windows 95 or better, so I installed Linux _______________________________________________ LinuxPLC mailing list [email protected] http://linuxplc.org/mailman/listinfo/linuxplc
V Power Generation 2
Y Languages 1
J Programmable Logic Controller - PLC 1
J LinuxPLC Project 3
A LinuxPLC Project 1
