W
Looking for a Slip ring assy that will xmit gate commutations between my controller card and a VR (Virtual Reality) Gun that the customer will use. Also has Recoil unit needing low power xmission (.5A) Details: I will be using this swivel to move 5 signals (on/off) when an action is done (i.e. trigger is pressed, trigger gets grounded). This is sent to a HD15 (which I can change to a DB 9). This signal is send to a controller card that tells the game that the trigger was pressed. Then a recoil signal is sent. The swivel will handle the power for the recoil also (.5 amps MAX measured at 330ma). Any help on where to source these would be appreciated. Thank you all. William
